starsnstripers
- Nov 30, 2007
- 1,330
1969-70 165hp 250cid L6 mercruiser> O/D # 2462278= 1969> I have two wires coming out of the transom plate below the steering shaft. I have 2 hyd. lines on each hyd. lift cyl. I have a three button trim tilt control and a little gauge with a little outdrive in it (to show the posistion of the outdrive) What i dont have and dont know if this system needs it cause it's not here, is a trim sender that i see in alot of photos that is mounted above the transom plate that two hyd lines coming from it and a wire or two.(see attached) Are the two wires comming from the outdrive to take the plase of the transom mounted trim sender OR?
