Hi, I'm the guy who bought the 86 evinrude 60hp with a dead top cylinder (no compression whatsoever), incase anyone remembers that godaweful thread. So i've decided rebuilding that motor isn't worth it. The lower unit and lower midsection housing is pitted and corroded so bad i cant justify anymore expense towards the motor, not to mention no trim and tilt anyhow. So i've recently found quite a deal on a 1997 johnson 50hp. Of course compression and spark tests are on the top of my roster, but is there anything i should be skeptical about other than that. Any other things to watch out for than compression, spark and lower unit? lemme know... I know you will; this forum is the best.
