I understand that the more recently made PT plywoods can cause galvanic action problems. I was wondering if marine plywood also falls into that category? Also, when searching these forums I see standard plywood often recommended. How does that work out? Is that only when it is glassed in? The deck will be carpeted. I have done many searches and understand the pros and cons on the carpet, I am just a little dizzy on the deck itself.
TYIA
Re doing a deck on an aluminum 16' vee to give a reference to the whole question.
dw
TYIA
dw
