CaptainBruce
- Jan 10, 2008
- 8
Hi All...
New to the forum,
and looking for a little help?
A little history...About 2 years ago The oil injection pump quit working causing my motor to lock up. I really wasn't sure what I wanted to do with my "Classic" Ranger Bass boat.(Junk it or fix it?)
I covered it and let it set for about two years..
I finally decided I really miss playing with that boat and now want to fix it...
I wanted keep the cost down ...so ,so far I have done all of the work myself.
I bought another used block ,that was is working condition.I checked the compression and that seems fine.I also replaced all of the vacuum lines,water lines,fuel lines,and hoses.I disconnected the oil injection system (this time) because I will add the oil to my gas.I don't want this motor to lock up like the last one did.
Now my problem....I have spark and gas (I took all of the plugs out and shot a little gas/oil mix into the cylinders...and all the motor will do is back fire about every 15 seconds...
Any Ideas on why it won't start?
CaptainBruce
New to the forum,
CaptainBruce
