Omg "unreal" Help !!!
starsnstripers
You guys aren't gonna believe this one! 250ci 165hp L6 The fitting broke were the oil sendr goes. I drilled it a little and managed to break the easyout off in the fitting. The n i took a 1/8 drill and drilled beside the broken easyout to try to break it free which i was able to do. I got the piece of easyout out. HOWEVER the 1/8 drill bit broke when got thrugh the fitting and it broke off INSIDE. It is in the oil journel somewhere. ANY suggestions??? :(
starsnstripers
Re: Omg "unreal" Help !!!
Here is a picture of the hole it's btween and below the lifters just above the cam. The drill bit is about 1.5" X 1/8 could i get to it by taking off the oil pan or ??? GRRRR !!!:( suggestions?
starsnstripers
where does that oil port cavity come out? I'm just beside myself i dont know if i can leave it or get it out...
starsnstripers
How about a diagram of the lubrication plumbing of a 259ci block? any such thing?
starsnstripers
how about take the oil pump off and blow compressed air in the sender hole?
ziggy
ya may be alright sns, i think there's a plug at ea. end of the block that is a oil gally clean out passage. my guess would be take the plug out and ya should be able to see it. with luck....
i think that small plug is a clean out passage
it's in line with the oil sender.......
if i'm right, i'd think ya could go after it with a magnet once the plug is removed..... hope i'm right...... what a sinkin feeling just thinking about yer delema.... good luck....
Bt Doctur
For next time something like that happens
drill and retap with a 1/8 pipe tap,crank engine to force oil thru hole to clean
drill a hole and use a "allen wrench" has a straight shank,wont jam up,plus drilling the larger hole relieves the stress on the remaining threads
worst case, drill and retapfor a smaller plug,threaded bolt,etc. and forget oil pressure
starsnstripers
Hey you might be right i didnt think of that. Thanks "i'm on it" I'll be back with the news thanks Zig
MikDee
Banned
You might want to magnetize a long thin tool, or a piece of ordinary steel "tie wire" by holding a strong magnet against it as you try to attract, & pull out the broken bit.
starsnstripers
That worked great, Your my hero Ziggy> haha! All i was trying to do was put a mechanical gauge on the engine to start it geesh. Some small jobs I'll tell ya, they can turn into a nightmare quick. Thanks for the other responses too. Here are the drill bit pieces that came out of the oil cleanout. I had to make a tool to get that plug out, it's a smaller sqaure hole than 3/8 and bigger than 1/4 drive.
starsnstripers
Well the operation was a success. I got her started today and she purred. Had 38 psi oil pressure at idle. no smoke and ran smooth. Thanks people for your help.:D
starsnstripers
Yes 36-38 psi oil pressure at idle cold engine, didnt run it long no cooling hooked up.
