  #1
Old March 7th, 2008, 05:27 PM
balls1 balls1 is offline
Default 2006 185 sport engine runoff
have a problem with run off on my 2006 185 sport dealer said it's a problem with all of them what can i do its a 4.3L
  #2
Old March 9th, 2008, 04:24 AM
oops!'s Avatar
oops! oops! is offline
Default Re: 2006 185 sport engine runoff
hey balls....welcome to i boats....
up in the main forum is mercruiser engine troubles.
the people here are fantastic......only wish i was in there area....id go to them........post your engine size and all the info you can think of.....youll have 50 answers in a matter of minits from some of the best mechanics in the states
  #3
Old March 14th, 2008, 08:10 AM
nlain nlain is offline
Master Chief Petty Officer
There are several things that cause run on after the switch is turned off. You have too much heat in the engine compartment, bad gas, idle speed too high, shutting down too quick after a long run. I would try turning the blower on for a few minutes, let the engine idle at the dock a couple minutes, this will do two things, remove heat from the engine compartment with the blower, idle time will let the hot spots in the engine cool down. If this does not work drop the idle speed 25 rpm maybe as much as 50 rpm, I would try 25 first.
__________________
http://myboat.wikispaces.com/
2004 Sea Ray 185 Sport, 4.3L,190, Alpha
1994 GMC 4X4 1500, 5.7L
  #4
Old May 7th, 2008, 04:45 PM
rktktpaul rktktpaul is offline
I have the same problem; I was told its very common. There is supposed to be a "run-on" fix, but the primary cause is heat build-up in the engine compartment, especially when running off plane. My dealer recommended that I run the blower continuously when off plane, and use a mid-grade gasoline instead of regular. It helped somewhat, but the engine still gets the hiccups from time to time.
__________________
"It's All Good!"
'06 Sea Ray 185 Sport
4.3l Merc/Alpha I
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2006 Sea Ray 185 Sport Issues cburg Sea Ray Boats 7 March 10th, 2008 09:26 AM
2006 Chevy Tahoe with 5.3L engine blue77 Trailers and Towing 18 September 12th, 2007 10:39 AM
2006 185 sport owners ruf1967 Sea Ray Boats 0 November 4th, 2006 09:56 PM
ENGINE 200 HP Evinrude etec 2006 pons Johnson & Evinrude Outboards 5 June 21st, 2006 03:53 AM
2006 SeaRay 185 Sport new2boating_00 Boat Topics and Questions (not engine topics) 11 February 19th, 2006 03:46 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
