I started my 25Hp Mercury 2 stroke a couple days ago. After leaving it for a couple days I went back today to ove it off its stand and onto my boat and noticed a pool of black oil under it (had to be lower unit oil). I removed the prop and saw a trickle of oil coming from the seal where the prop shaft goes into the lower unit. Can anyone tell me if this is hard to replace as I just see a metal plate which looks to hold the seal in place, and is it as simple as removing that plate and replacing the seal and then putting the plate back in place.
