I have a question about the oil seals under the water pump on my 1998 115 Merc.
I bought the engine new, and from the first oil change I was concerned about the appearance of the LU oil. It has always been a yellowish color.
This year I decided to replace the seals under the water pump impeller. In doing so I found some things that have me stumped.
The two seals that came out are marked 26-43036 and 26-43035. I looked up the specs on these seals, and they are designed for shaft sizes of 1.045 and 1.063 respectively.
I measured the sealing surface of the drive shaft and it is 1.025.
My questions are:
1) How could seals designed for 1.045 & 1.063 dia shafts seal effectively on a 1.025 shaft ?
2) Why would Merc specifiy seals for 2 different shaft sizes ??
Thanks for any help you can offer.
My questions are:
