Overheating indication. I had problems a few years ago with a faulty stbd side sensor and replaced it. Boat ran great for past 2.5 years. Problem has come back again on the stbd side again. I had it in to the local shop and they could not get it to duplicate (only happens under load at 4K rpm and above as near as I can tell). They replaced the sensor again and today I took it out. Alarm came in a couple of times. I checked it again and unplugging the stbd sensor stops the alarm(definitely stbd side is causing the problem). Compression checks are good @ 120 on all four. The shop guy thinks the head gasket may be leaking into the cooling jacket under load. Even when the engine is in alarm the temp on the water jacket does not seem that hot. A non contact pyrometer says the stbd is running at 168 degrees F. I have removed the t/stats again today and boiled them and monitored the temp. Both work fine, no corrosion, nothing.
Does anyone know if these are identical or not? One is marked 23FU (port) and the other is marked 23EU (stbd) are these temp ratings or what. Any help would be appreciated. By the way the water pump is good. It runs at 25psi by the console gage 4K rpm.
