  #1
Old March 6th, 2008, 04:23 PM
rernst rernst is offline
Default 1960 40 hp Evinrude Lark II engine connector info
I have a 40 hp 1960 Evinrude Lark II that has the electrical connector on the starboard side with 7 connections. 2 small, then one large, then 2 and 2 more small. Sort of like this:
* <----- this should be centered and is large post
I have the Seloc manual for the engine, but I can't find a listing that shows the connections on this. And I don't currently have the original wiring harness to check either. From looking at the engine, it looks like the large one is for the starter and normally comes from the solenoid to start the engine.
This engine has no generator, but I assume one or two of the connectors would be used if it did have one.
My understanding of these engines is that two connectors go to the coils/points and are used to kill the engine when they're connected together.
What I want to do is rig something up temporarily (I don't know if the engine will even run, so don't want to invest in more than necessary to try it out) to test it.
Thoughts were to connect an off/on "kill" switch to the connections for the coil/points that are used for this (or just choke it to kill). And connect with heavy duty battery disconnect switch directly to the starter itself for starting.
BTW, these don't have recoil starters, and while they seem to have the "pop off" valves (if that's the word for 'em), to allow hand/pull starting with a rope, they do not have the gadget that opens 'em when cranking as my old '58 had, so it would seem the best bet would be to just use the starter itself (also easier on my back...
Thanks for any help identifying what the actual pins go to on the engine.
Rich
  #2
Old March 6th, 2008, 06:03 PM
Chinewalker's Avatar
Chinewalker Chinewalker is offline
Default Re: 1960 40 hp Evinrude Lark II engine connector info
Hi Rick,
Your motor should have a recoil on it. If not, someone has removed it. It will have the bosses for mounting one, in any case. I think I may have a spare kicking around if you need one.
Also, the motor will run just fine with that plug not plugged into anything. Wiring harnesses with solenoid boxes turn up all the time on eBay and such. Woth a shot at the AOMCI site's Webvertiser, too. I have a plug end at the shop, but it has been cut about 3 feet from the plug - no box with it. Not sure if it is a 5 or 7 pin plug...
You should be able to sort out the pins pretty easily by following the wires inside. Use a multimeter set at the conitinuity setting and note where each wire goes to which pin. You'll have the choke circuit, kill circuit, charge circuit (should be closed off if you don't have a generator), and main positive feed (large pin). Not much else in there...
- Scott
__________________
Share A Project Page for 1971 GW Invader Banchie 13
http://www.shareaproject.com/pages/p...,p,433,00.html
Share A Project Page for 1976 American 18
http://www.shareaproject.com/pages/p...,p,404,00.html
Share A Project Page for 1974 American 15
http://www.shareaproject.com/pages/p...,p,405,00.html
  #3
Old March 6th, 2008, 07:14 PM
F_R F_R is offline
The screw that holds the electical plug into the socket is the ground cable.
As said, you don't have to hook anything up. Just choke it and crank it and it will run as is.
  #4
Old March 6th, 2008, 07:28 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
you have a pm.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #5
Old March 6th, 2008, 07:39 PM
Quote:
Originally Posted by Chinewalker View Post
Hi Rick,
- Scott
Thanks, I'm hoping to avoid all that work just to try to start it. And most of the wires disappear under other things, not something obvious. Strange that the connector isn't documented, at least in the Seloc book. (I'm an old hand at car stuff, and usually, all the plugs are documented)
But, are you saying the large connector isn't the starter connection, but is the main power to the engine? I thought that one I did follow since it has a large wire attached, and it went directly to the starter itself.
Quote:
Originally Posted by tashasdaddy View Post
you have a pm.
What's a pm?
  #6
Old March 6th, 2008, 07:46 PM
Evinrude Boater's Avatar
Evinrude Boater Evinrude Boater is offline
Master Chief Petty Officer
The large pin is the positive lead to the starter. The generator wires are blue and yellow and they're usually capped off and tied up in the bottom engine cover. Grounding the ignition will stop the engine, that's what the vacuum kill switch does in the event of a runaway condition. There's two mercury switches on the throttle on the port side. These prevent the engine from being started when the throttle is set too high. You'll have to deal with them too. E-mail me if you want a colour wiring diagram.
With the recoil starter removed the flywheel will be exposed such as in the photo. There would be a ratchet plate attached to the flywheel. The one shown in the photo broke apart and since the ignition inspection hole cover was missing, the broken pieces went down into the ignition. Not good!
  #7
Old March 7th, 2008, 12:57 AM
GREAT, thanks. Yes, please do send details on wire colors and what they go to, that'll help a lot.
Ok, good, big pin is starter. I can trace the overspeed vacuum switch (I think I know which that is, and if not, can look it up in the Seloc manual), to make a "kill" switch connecting the two points wires or the same wires as at the vacuum switch.
Good to know about the generator as well, as I did see 2, or possibly 3 wires in the bottom near the connector that looked professionally capped off.
Oh, there is no recoil pull starter on this. Actually, I wound up with two, identical, supposedly from same boat in my deal, and neither have the recoil starter assembly. Is it possible they're missing as coming from the factory, or did the Lark II models always have 'em and they both were removed at some time, for unknown reasons (just 'cause they're 48 years old?
  #8
Old March 7th, 2008, 03:35 AM
F_R F_R is offline
They had recoils when they came from the factory.
  #9
Old March 7th, 2008, 08:05 AM
a PM is a private message, if you look at the top of this page, under Welcome Rernst, you will see in blue, private message. it is a way we can communiate privately. i want your email address so i could send you the complete wiring diagram for that motor.
__________________
FLORIDA GATORS
TEBOW Country
  #10
Old August 13th, 2009, 01:20 PM
rican69m rican69m is offline
looking for a wiring diagram for this engine ,trying to get it started ,if anybody can help ,thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1960 Evinrude Lark II, 40hp - Broken Belt glenclove Johnson & Evinrude Outboards 7 March 10th, 2008 09:53 AM
1960 Evinrude 40hp Lark, LU Overhaul Evinrude Boater Johnson & Evinrude Outboards 8 February 26th, 2008 10:57 PM
Steering connector for Evinrude Lark cheburashka Johnson & Evinrude Outboards 5 July 28th, 2005 10:04 AM
1960 Evinrude Lark E 40 HP thottle stuck at full planthead Johnson & Evinrude Outboards 4 May 26th, 2005 04:56 PM
1960 Evinrude Lark 40 - Coil Wiring esmwolfe Johnson & Evinrude Outboards 2 November 21st, 2002 06:48 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
