  #1
Old March 5th, 2008, 01:39 PM
kmchugh kmchugh is offline
Default Evinrude Gearcase leak
I just bought this 1968, 9.5hp Evinrude, and after changing the gearcase oil, it seems to be leaking. The oil is coming out a weep hole under the cavitation plate. If I wipe if off and come back a day later the drip, is there again, however each time there is less oil. Does this mean if have a cracked lower unit? I'm not sure the oil leaking is actually 90 weight oil. Another point of interest, is that it may have been shipped upside down.
  #2
Old March 5th, 2008, 01:46 PM
PmDavis300 PmDavis300 is offline
Default Re: Evinrude Gearcase leak
might be the unused fuel/oil mix? thats what happened to me. its leaking out above the gear case?
  #3
Old March 5th, 2008, 02:22 PM
ezeke ezeke is offline
If it is coming out of the drain hole, it could be either a spill, or a cracked housing, but probably is neither one.
The spent oil from the engine runs down with water and exhaust and out the back end of the gearcase. It partly fills the midsection to cool and muffle the exhaust. When the water runs out, the oil runs slower.
  #4
Old March 5th, 2008, 05:25 PM
It's good to know that it's not definately a crack. The previous owner may also have fogged it, and now like you say the excess oil flowing out. One other fact I didn't mention earlier was that the grease in the gearcase looked milky. So I guess I'll have to keep an eye on it.
Thanks for the feedback!
  #5
Old March 5th, 2008, 05:42 PM
The 9.5 unit is like most gearcases, the water usually gets in through the vent and fill plugs when the nylon flat washers fail. It really is better to replace them whenever you open the plugs. I finally started buying a bag of 50 here at iboats, just so I would have them around. (Sierra 18-42481-9)
The 1968 9.5 is easy to reseal if you ever have the desire to do it. The hardest thing is getting the screws loose that hold the skeg. I have always had to use a hand impact tool to get them started.
There are two different seal kits for 9.5 gearcases; 1967 and back (Sierra 18-2682) and 1968 and up, (Sierra 18-2683). The problem is the whole drive is interchangeable so you have to be sure which drive you have. Fortunately, the kits don't cost that much.
http://www.iboats.com/mall/partfinde...****=380337163
  #6
Old March 5th, 2008, 06:57 PM
cc67's Avatar
cc67 cc67 is offline
"I have always had to use a hand impact tool to get them started."
Me Too. That is why I have started using allen head screws when I reseal a lower unit. Usually the original ones get too buggered up to reuse.
  #7
Old March 5th, 2008, 07:00 PM
Where did you find them?
  #8
Old March 5th, 2008, 10:51 PM
Evinrude Boater's Avatar
Evinrude Boater Evinrude Boater is offline
Master Chief Petty Officer
Quote:
Originally Posted by cc67 View Post
"That is why I have started using allen head screws when I reseal a lower unit. Usually the original ones get too buggered up to reuse.
Oh, I like that. My 40 hp is all apart now so maybe a good time to replace the screws. Why didn't they just use hex bolts on them?
  #9
Old March 5th, 2008, 11:16 PM
cc67's Avatar
Any good hardware store should have them. The allen heads are are the same head size as the slotted ones so they will fit in the in the skeg. The ones I use are just a tad longer than stock so they grab a few virgin threads. I believe they are 1/4 x 20 NC.
  #10
Old March 6th, 2008, 08:36 AM
Just for reference, I found a good on-line source here in Weymouth MA for hardened stainless socket (Allen) screws.
Stainless socket screws- copy the link without the quotation marks: "http://www.boltdepot.com/dimension.aspx?cc=13&cs=71&cm=6"
  #11
Old March 9th, 2008, 10:34 PM
bearddd29 bearddd29 is offline
ive got an 18 hp johnson and does the same i think its old unburnt oil fuel mix
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
BF100 oil leak from gearcase jurikfishing Honda & Tohatsu/Nissan Outboards 2 July 23rd, 2007 07:06 PM
gearcase leak? _mako_20 Johnson & Evinrude Outboards 5 January 21st, 2006 09:43 AM
gearcase leak danberlin Honda & Tohatsu/Nissan Outboards 11 November 20th, 2005 11:15 AM
Gearcase leak Grant Brown Mercury & Mariner Outboards 1 November 7th, 2005 09:39 AM
3hp evinrude 1960's weedless gearcase of 90 deegree gearcase Tom987 Johnson & Evinrude Outboards 3 November 6th, 2004 10:43 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
