  #1
Old March 4th, 2008, 11:03 AM
jfbetz jfbetz is offline
Cool Yamaha 250 Compression
I am considering pulling the trigger on a pair of 1999 Yamaha 250's. I've read a lot about compression and gathered that consistency throughout cylinders is most important. The motors are reported to have 110# throughout all 12 cylinders. I have seen other motors with higher compression (115-125). What is the difference between consistent 120# compression and 110# compression? Any performance issues? Is lower compression necessarily a sign of remaining engine life?
Thanks,
  #2
Old March 4th, 2008, 06:33 PM
mpsyamaha mpsyamaha is offline
Default Re: Yamaha 250 Compression
often times there is fluctuation between gauges so the same motor will read 20psi different with two different gauges. also it depends if the test is being done with the throttles open or not. and if you put a little oil in the cylinders it will come up. so the point is it may not be low on compression.
in my opinion, if all 6 cylinders are extremely close to the same, its good to go.
i dont like to take peoples word for it with compression. see it for yourself if you can.
  #3
Old March 4th, 2008, 06:39 PM
rodbolt rodbolt is offline
on most 3.1L yamahas you will see a 5 PSI variation as you go down the bank. compare 1-2,3-4 and 5-6 all should be within 10 PSI bank to bnk.
I have seen a few replacement powerheads with 80 psi on one engine and 120 on the other with no performance issue.
2 strokes dont die like 4 strokes, usually your first indication its failing is when it does.
  #4
Old March 4th, 2008, 08:27 PM
Thanks for your reply's mspyahama and rodbolt.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
RODBOLT or yamaha guys! Yamaha 50hp 4 stroke low compression question! oonighttrain Yamaha & Suzuki Outboards 8 January 22nd, 2008 10:19 AM
95 Yamaha 200 compression grouperkng Yamaha & Suzuki Outboards 1 January 2nd, 2007 10:02 AM
Yamaha 250 EFI Compression ? gomac Yamaha & Suzuki Outboards 2 October 15th, 2004 04:21 AM
Yamaha 250 compression Knot Working Yamaha & Suzuki Outboards 3 April 8th, 2003 06:03 PM
Yamaha Compression HELP!! JohnBNTampa Yamaha & Suzuki Outboards 6 February 17th, 2002 11:48 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
