96 Yamaha 50hp - Fast Idle
All
I have an interesting issue with my 96 Yamaha 50hp. This happens if the engine is warm or cold. It also happens consistently.
If you turn the engine off (even if warm) and restart, the idle acts almost like it is the cold start high idle - 1300 RPM (on the tach). After you put it in gear, and run it, and go back into idle, it will idle normally. Only after you turn it off and turn it on again does it have the "high idle" regardless of engine temp.
I do have the factory manual, but I don't see any trouble shooting tips in the fuel section.
The other bonus is that I have a spare motor that had the crank snap - came with the boat - PO bought it off of craigslist. So I can easily do part swapping for debugging if necessary.
Any ideas? Again, I appreciate your input and assistance.
Thanks
Jack
