Re: Lubriplate
What outboard are you talking about in this thread? Lubriplate 105, or white engine assembly grease, can be used in LU's. It was the standard lubricant for this application until the petroleum companies started marketing the hypoid oils for marine applications. It won't emulsify with water like hypoid oil, but it is no substitute if your outboards specs call for more modern oil. As said earlier, replace the seals if it needs it...that's a lot cheaper than replacing the gear set and seals together.
