Hi guys new here!
Have a bit of a problem.
I just purchased a Quinnie Classic 560 Runabout 2000 model millenium hull matched to a 2005 Yamaha 4stroke 80Hp. It has a 17pitch prop with no hydrofoil.
The hull needs alot of work and im currently in the middle of a total strip down repair and respray back to the factory paint and decals.
I took the boat out for a test prior to starting work on it. Im under the impression the boat is underpowered and need some opinions please.
With just myself in the boat and 20L of fuel it planes easily and hits 5200RPM at WOT with the right trim ajustments. With 4 people it still planes easily but speed is hampered and I get the feeling the engine is working too hard. It only hits 4700RPMS at WOT no matter how you trim it. I can only imagine the strain with a full load 6 people. Its lugging.
Hull plate reads 495kgs hull weight max HP 115.
I was wondering if going down to a 15pitch would solve the problem. I was told by a marine place today that the engine would be much more responsive with a full load and probably hit 5500RPMS. With a light load it will hit 6000rpms which is what its rated to. (5500-6000) factory specs. I guess a hydroil ontop of a prop change might solve the problem ? Im thinking 14pitch.
OR do u guys think its underpowered. Worse case i might have to trade in the engine in for a 100 or 115 4stroke yami which i would like to avoid $$.
Thanks in advance Robbie.
