Where are the drain plugs on a big block (GM) Mercruiser
donwhiteside
Hi- In warm California, we don't need to drain for the winter. But, I'm pulling the heads to replace gaskets and need to get the water out of the block. I can't find the drain plug (plugs??) on this 1973 Mercruiser 325 (basically a 427 GM truck engine).
Thanks!
Don
Haut Medoc
Re: Where are the drain plugs on a big block (GM) Mercruiser
I'd think there are one on each side like any GM V8 + a plug on the transmission oil cooler.....;)
Ayuh,........
Down Low on each side of the Block, just above the Pan Rail..........
1 just ahead of the Starter,+ 1 just ahead of the Oil Filter......
HT32BSX115
So when you say "warm" Ca. where are you talking about?
My brother lived in Novato, (warm) Ca and thoroughly cracked a 460 block and manifolds in the not too distant past!
It gets plenty cold in the San Joaquin Valley to crack a block too.
When you pull the plugs you may have poke a small screwdriver in the holes to clear the sand and rust.
Cheers,
Rick
(used to live in Warm Ca.....Now I live in Warm Wa)
Thanks!
Don
BAYLINER185
Your are problably just like the ones on my 7.4 ( 454)
they are brass I beleive and could be removed with a special wrench.
I dont know why they are not removable by hand like on my 4.3 engine.
I live in Phoenix AZ and it dont freeze either but it sure is damn cold now. I dont plan on using the boat as much now as I did in warmer weather but I think its a good idea still to drain the blocks water as much as possible as to prevent rust from the water standing in there.
I did drain my 4.3 and was supprised at howm much water came out. I can only imagine how much is in a 454.
Ayuh,..........
Nothing Special about a 9/16" End-Wrench.........
That's what All of them were before the advent of the Useless, POS, Junk, Breakable Plastic 1s of the last few years.................:rolleyes:
Don S
They get 8.50 for that mess Bondo, or you have to spend 2 bucks at your local auto or hardware store for a brass hex plug.
Ayuh,.........
Do they include the Written Guarantee that says they Break the 1st time you use'em,..??.........:D
Don S
No, but they will sell you a new engine if you overheated and blew it up ;)
ziggy
from my understanding. more rust occurs w/o water than with water. the damp inside w/air starts to rust. with water inside, no air, no rust..... a little rust is better than freeze damage though......
