  #1
Old February 26th, 2008, 02:43 PM
redsmufc redsmufc is offline
Default evinrude 40hp lark 1968 water pump trouble
Can anyone help me? I have recently rebuilt the lower unit on a 1968 evinrude 40hp lark.
I have put it all back together and i have no water being pumped out.
I have taken it apart again to check for blockages, if the 2 tubes are located properly, and if the impellor is the correct way round. all seem ok put still not working.
I have replaced all the seals in the lower unit, the grommets and the seal on the bottom of the inlet tube. and still have no joy.
It seems to be a pick up problem.... please HELP!!!!!
  #2
Old February 26th, 2008, 04:11 PM
Default Re: evinrude 40hp lark 1968 water pump trouble
I have just been told that it could be the inlet tube seal not seated correctly, or the impellor plate not sealed.
Could this be the answer??????
  #3
Old February 26th, 2008, 04:21 PM
R.Johnson R.Johnson is offline
If you remove the thermostat cover while running, do you have any flow at all?
  #4
Old February 26th, 2008, 04:26 PM
I have check that out and there is nothing reaching that point also check tubes for blockages and they seem ok. Thanks for reply
  #5
Old February 26th, 2008, 04:37 PM
Did you put in new pump parts? Have you checked the inlet screen? On top of the pump housing there is a thick o-ring, this must be in place, is that there?
  #6
Old February 26th, 2008, 04:42 PM
the inlet screen seems clear i have fitted new seals to the pump housing and new seals on the tubes, and the oring is brand new aswell..
  #7
Old February 26th, 2008, 04:51 PM
iwombat's Avatar
iwombat iwombat is offline
remove the t-stat cover and hook a hose up to the inlet tube (w/ LU off). You should get a nice unrestricted water stream when you turn the hose on.
  #8
Old February 26th, 2008, 04:52 PM
Is that an all new water pump, including the housing?
  #9
Old February 26th, 2008, 04:54 PM
have done that and there is a constant flow thanks
  #10
Old February 26th, 2008, 04:57 PM
hi the pump housing is not brand new although it looks fairly new. i did re seal it though.
  #11
Old February 26th, 2008, 04:59 PM
iwombat's Avatar
Well, that removes a blockage from the list.
Maybe you should describe your set-up for testing this motor. Muffs or barrel. If barrel how high is the water on the midsection?
  #12
Old February 26th, 2008, 05:04 PM
If every thing is as you discribe, I am lost as to where the problem is. As the other post ask's how are you testing?
  #13
Old February 26th, 2008, 05:06 PM
i have been testing this in a barrel i filled it to about 4" above the water pump housing level..
is there anyway of testing the pump is picking up without the lu being connected to the main unit??
also should i try re sealing the impellor plate??
or is there a special way of installing the seal on the lower part of the inlet tube???
  #14
Old February 26th, 2008, 05:30 PM
Not only seal the plate down, look at the walls' of the cavity under the plate, and see if there are any cracks', or breaks'.
  #15
Old February 26th, 2008, 05:41 PM
i don't think its cracked but i'll double check tomorrow to make sure. Its starting to baffle me
many thanks for your help!!!!!!
  #16
Old February 26th, 2008, 05:57 PM
Evinrude Boater's Avatar
Evinrude Boater Evinrude Boater is offline
Master Chief Petty Officer
Mine is cracked. I hope that isn't a problem for pumping water. As I understand it can allow exhaust gases into the water and heat things up.
  #17
Old February 26th, 2008, 06:02 PM
im hoping its something i've done maybe not sealed properly i hope lol
  #18
Old February 26th, 2008, 06:04 PM
The drive shaft is 5/8" diameter so if you have a 3/4" chuck you can spin it in a barrel and see what happens.
  #19
Old February 26th, 2008, 06:09 PM
many thanks ill give it a go
  #20
Old February 26th, 2008, 07:00 PM
HighTrim's Avatar
HighTrim HighTrim is offline
I assume you remembered the impeller key right?
__________________
Chris
  #21
Old February 26th, 2008, 07:13 PM
Evinrude Boater: There was a OMC service bulletin on this in the early years of these type engine's. The cracks' can cause the condition you discribe. Did,nt we discuss your engine in an earlier post, with some idea's on how to fix it?
  #22
Old February 26th, 2008, 07:58 PM
K.B K.B is offline
Just now read the post. I have a 71 40 hp ev. that I had trouble w/a couple of yrs. ago when it was new to me. May not have a bearing on yours but sounds familiar to me. My head gasket was blown and would NOT pump water. Wrench told me to check the compression and see if the gasket was the problem and sure 'nuff. Replaced and been @ 110 on both cyls. ever since.
Just for the fun of it all, check.
  #23
Old February 26th, 2008, 08:02 PM
K.B K.B is offline
Oh yeah, mine has no thermostat so I know nothing about that kind of problem. "Flathead" so to speak!
  #24
Old February 26th, 2008, 08:14 PM
K.B That certainly is not out of the question, it certainly seem's to be a puzzle.
  #25
Old February 26th, 2008, 10:49 PM
Quote:
You're right R.Johnson, mine has a few cracks and I think I will JB Weld them.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1968 evinrude 40hp lark water pump trouble redsmufc Johnson & Evinrude Outboards 12 October 7th, 2007 03:58 PM
1968 Erude 40hp Lark - Cowl? jai070404 Johnson & Evinrude Outboards 2 July 8th, 2004 11:16 PM
1968 Erude 40hp Lark - corrosion. jai070404 Johnson & Evinrude Outboards 2 July 4th, 2004 06:35 PM
Manual for 1968 erude 40hp Lark jai070404 Non-Repair Outboard Discussions 1 July 4th, 2004 06:24 PM
1968 40HP Lark spark plugs jai070404 Johnson & Evinrude Outboards 8 June 23rd, 2004 09:46 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
