  #1
Old February 26th, 2008, 10:16 AM
pancakes pancakes is offline
Default yamaha pro 50 power tilt hydraulic failure
i have a motor stuck in the down position due to an apparent hydraulic failure in the lift cylinder. i assume it IS a problem with the piston and not the lift motor because i can hear the motor run in both directions but there is absolutely no lifting happening. 3 questions: 1) where is the manual relief valve on a 95 pro 50? 2) what is the likely failure within the piston. o rings? could it just need to be bled? 3) could a piston overhaul be accomplished by a novice mechanic or should i haul the boat in for service?
thanks
  #2
Old March 16th, 2008, 11:22 PM
jl_photo jl_photo is offline
Default Re: yamaha pro 50 power tilt hydraulic failure
there is a slotted screw on one of the motor mounts near the trim pin holes. counter clockwise should lower the motor, or alow you to raise it by hand.
try running the tilt motor with the manual valve open and slowly close the valve. if the pump is pumping then you should feel the rush of fluid when the valve is almost closed.
you may be out of fluid. I think you should be able to lift the motor by hand when the valve is open and then add fluid. secure the motor well to avoid being squashed if the motor falls.
rebuilding the cylinder requires a special wrench. there are some valves inside that may be very difficult to work on.
the seals are not replaceable on all models, the entire ram and seals are replaces as a unit. this is easy after you get the cylinder cap off.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mercruiser power tilt/trim pump failure jimLINY Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 May 22nd, 2008 02:40 PM
Hydraulic hose for power tilt. holloway Johnson & Evinrude Outboards 0 June 11th, 2007 10:39 PM
Yam Power Tilt Failure black-hawk19 Yamaha & Suzuki Outboards 4 May 16th, 2007 04:05 AM
Johnson power tilt/trim failure buckshot Johnson & Evinrude Outboards 2 July 4th, 2006 10:58 AM
need hydraulic cylinder for power tilt AmigaDragon Johnson & Evinrude Outboards 0 July 12th, 2003 12:05 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
