Re: bellows on alpha 1
If you are going to remove the bell housing to replace the ujoint bellows, you really should replace the shift cable and shift cable bellows also. If the bellows are over 5 years old, they both are due. To replace the shift cable bellows, you have to remove the shift cable, completly disassembling it. I have found that trying to reinstall a used cable, usually leads to a stiffer cable, which will lead to engine stalling because of the shift interupter. Spend the money, and replace the cable while you are in there. If you do both bellows, the cable, and the water hose, you are covered for years to come! If the trim gauge is not working, this is the time to consider the trim senders too!
The tools are expensive. If you go to your dealer, you may be able to strike a deal. Give them the business of buying all the parts from them, as opposed to buying them online, and they may loan the tools to you, or rent them to you. Buying them is not worth it, because if the job is done right, you won't need the tools again for several years.
Good luck!
