  #1
Old February 25th, 2008, 03:57 PM
stogie5150 stogie5150 is offline
Default Bent Tilt Cylinder Ram 1995 Yamaha Pro 60...how hard to fix?
I needed to replace the steering tube on my pro 60 due to a corrosion issue, and, not knowing any better, I just removed the tube and let the motor sit. Well, I went to install the new tube, and discovered that the weight of the motor has bent the tilt ram...DOH! <slaps head> Now, I have the means to remove the motor from the boat, and have the tools to remove the assembly...what I DON'T know is how the hydraulic lines remove and how do I bleed the assembly after I change the cylinder, or is the Yamaha system self bleeding? The last trim system I worked on was on a Mercruiser 20 years ago...so I am ignorant on it.
I DO have the Yamaha manual, and it looks straightforward, remove the split ring on the pin at the top, remove the bolt at the bottom, remove the two hydraulic lines, and that's it...or is it?
Some pictures of my utter stupidity and ignorance, in hope that it stops some other shadetree mechanic from doing the same thing...
Last edited by stogie5150 : February 25th, 2008 at 09:42 PM. Reason: changed nonclemature
  #2
Old February 27th, 2008, 09:36 AM
Default Re: Bent Tilt Cylinder Ram 1995 Yamaha Pro 60...how hard to fix?
Update: I talked to a retired Yamaha mechanic, and he informed me that the trim/tilt unit, although Yamaha sells rebuilding parts for it, is not generally rebuildable, and generally they replace the whole unit. That unit costs over 2k new. Anyone had any success rebuliding just the tilt cylinder? In my case that would mean a new ram for the cylinder and replacing the o-rings and such.
I made an expensive mistake. ;-(
And 2000.00 money put into a 13 year old motor does NOT compute.
  #3
Old February 27th, 2008, 12:44 PM
bill k bill k is offline
You might start looking in the boat salvage yards
Bill
  #4
Old February 27th, 2008, 09:02 PM
rodbolt rodbolt is offline
myself, I would change mechanics, no wonder he retiered. the system is self bleeding. change the tilt ram and any orings you disturb and keep running. I rebuild several each year with no issues.
however I do have a bit of training and stayed at a holiday inn once.
  #5
Old February 27th, 2008, 09:30 PM
JustJason's Avatar
JustJason JustJason is offline
Rodbolt...
If i'm not mistaken... don't alot of those smaller yamahammers tilt motors pop out the back? I mean... you have to unbolt the clamp bracket and pick the motor up to remove that tilt motor.
The last one i did was last year on a 50hp.... and i had to pull the OB and once the clamp bracket was loose, i was able to swivel the clamp bracket and it came out the back.
__________________
just because you found it that way... doesn't mean it's supposed to be that way.
Part of diagnostics is spending time figuring out not only what the problem is, but also sorting through what it isn't.
The older the engine is, the chances of it having more than 1 problem goes up exponentially
Boating has always been a rich mans hobby. Buying a new boat gets cheaper every year, but the maintenance, the repairs, and the overall cost of ownership of a boat has never gotten any cheaper.
  #6
Old February 27th, 2008, 09:55 PM
usually you have to remove, or at least move the stbd bracket a few inches, sometimes with the tilt ram pin removed, if you can lower the ram, the engine will actually tilt higher and allow ram/cap removal with nothing else. however in the above case he is just gonna have to move the stbd bracket over about an inch.
  #7
Old February 28th, 2008, 08:59 AM
Quote:
Originally Posted by captJason View Post
Rodbolt...
Thanks fellas. The mechanic that told me that is considered a God by some, hated by others. My Late Father had a falling out with him before he died, I think I know why.
I have done a little work with Hydraulic rams before, I didn't see any reason why I couldn't just replace the ram itself, Yamaha sells the part for goodnessakes...BUT I don't have the spanner to remove the ram so I will have to hire out that bit of work. But I can remove the assembly and take it to someone so I don't have to leave my whole boat in their repair yard...
Two guys told me that the removal was pretty easy. My Yamaha manual says three bolts, and the tilt-ram pin, unplug the electrical wire, and it should pop right out, assuming the motor is held all the way up, supported by a chainfall.
Rodbolt, you spoke of moving the STBD bracket to let it clear, which bracket do you speak of? The motor mount is one piece where it bolts to the boat itself. I do have to remove the bracket-to-boat bolt for the lower tilt ram bolt because it will interfere with removal.
Last edited by stogie5150 : February 28th, 2008 at 09:00 AM. Reason: lumberfingers
  #8
Old February 28th, 2008, 09:05 AM
usually there are 3 bolts on each side and the stbd transom bracket will have to be moved over a bit. loosen the steering tube nut an inch or so,remove both bracket to hull bolts and move the bracket to the stbd an inch or so. do this after removing the trim motor wiring and the tilt ram pin. the cap tool isnt expensive and the universal one snap on sells will work.
  #9
Old February 28th, 2008, 09:23 AM
Quote:
Yep, I see what you mean. If I remove the steering tube a bit I just re-installed, the bracket will indeed come in two. Got it. The Yamaha manual isn't as clear as it could be, but I guess it is just because its written for professionals and not shadetree types like me... If it warms up a bit I might give it a go.
I saw the spanner, my 'pessimistic mechanic' had it, but after we argued awhile I didn't think it would wise to ask him to use it, although if I take the assembly off and bring it to his house he might relent... ;-)
Thanks Rodbolt, I'll check in if and when I make any progress.
  #10
Old March 3rd, 2008, 02:25 PM
Got it removed, took about an hour with a little help from a cousin of mine....thanks for the help y'all. Just like you said Rodbolt, move that starboard bracket out of the way and it just pops out.
Now I have to figure out how I am going to fix it, have the ram changed, since I don't have the tools, or buy a used whole unit, or what. I found a used whole tilt/trim unit online for 570.00. By the time I pay someone to change just the ram out and labor and all it might be very nearly the same in price.
I dunno just yet.
  #11
Old March 16th, 2008, 11:07 PM
jl_photo jl_photo is offline
I have a nice tilt cylinder from a 1996 C40 PLRU. look at the parts diagram and see if you think it will match.
http://www.yamaha-motor.com/outboard/parts/home.aspx
outboard
1996 outboard
C40 PLRU.
and/or I can measure the unit for you and we can see if it will fit
  #12
Old March 26th, 2008, 07:35 PM
UPDATE:
Got it fixed...I actually found a machine shop that has lots of marine experience that straightened the one I have, chucked it up in a lathe and showed me the run-out after he was done, less than .003 inch. He said that was the softest hydraulic ram he's ever seen. My mechanic said that the ram would not come off the piston, he said the nut at the end of the shaft was pinned in place with a press-fit pin.
He also admonished me to stop using Wal-Mart oil and cheap gas with no Ring Free in it...but that's another story...
But its done, thanks all for the info, once again this site rocks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Prop rubber shock absorber gruntpltleader Prop Questions and Topics 1 June 18th, 2007 03:03 AM
Hard starting 1995 Yamaha 115 mygrandson123 Yamaha & Suzuki Outboards 18 June 22nd, 2006 06:00 AM
What grade oil in tilt hydraulic damper (shock absorber)? Tinkerer Johnson & Evinrude Outboards 0 March 27th, 2003 05:09 PM
Force power tilt/trim shock absorber leaking from fitting. basj8yw Force & Chrysler Outboards 0 June 30th, 2002 08:12 AM
1995 Evinrude 48HP Bent Fin Terry G. Johnson & Evinrude Outboards 1 October 7th, 2001 05:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
