  #1
Old February 25th, 2008, 10:32 AM
phonedrn8's Avatar
phonedrn8 phonedrn8 is offline
Send a message via Yahoo to phonedrn8
Default Lanyard switch?
does a 89 capri have a lanyrd kill switch on it?
if so what is the proper way to hook it up?
and can i get a replace ment, Im thing when I got my boat from a p.s. they didnt give it to me just keys
__________________
phonedrn8
U.S.S what the hell
1989 Bayliner w/ Force 85 outboard
  #2
Old February 25th, 2008, 06:14 PM
gcboat gcboat is offline
Default Re: Lanyard switch?
If you have a kill switch it will located on your dash and be very obvious. Either in the form of a clip or a circular snap on device. Have you tried starting the engine? If it did start then you don't have one and don't need one. I'm really not sure if they were installed during that year model - should be though. Send me your HIN and I'll double check.
Never mind, found it - Yes, you should have one. Will be a round, red button that accepts the clip ( like a jet ski ). Will be located right next to the steering wheel pretty close to your ignition switch.
  #3
Old February 25th, 2008, 06:35 PM
MikDee's Avatar
MikDee MikDee is offline
Yes, it should be on the left of the steering wheel, a thin black cord (curled up, or just hanging) with a piece of plastic on the end, that acts like a spacer to keep the spring loaded switch in the out (run) position, they are available, but you can temporarly disconnect it under the motors hood, I forgot what color wire it is though, you just need to unscrew the wire loop, at the terminal block.
__________________
89'-19' Bayliner Capri Ski boat, with a 125hp Force
My Previous Boats http://smg.photobucket.com/albums/v2...ee/My%20Boats/
My motto - Keep It Simple Stupid
  #4
Old February 25th, 2008, 09:16 PM
See if any of these will work for ya' :http://www.dickssportinggoods.com/sm...i-1026753.html
  #5
Old February 25th, 2008, 09:27 PM
phonedrn8's Avatar
cool , is it a n/o or n/c switch?
i did look under dash and seen on wire is removed from the switch i guess i have to get it replaced. so I can start it
i do have kinda running as long as starter is engaged. it spudder, kicks bucks blue smoke kinda
__________________
phonedrn8
U.S.S what the hell
  #6
Old February 26th, 2008, 12:44 AM
BAYLINER185's Avatar
BAYLINER185 BAYLINER185 is offline
Send a message via Yahoo to BAYLINER185
Yea that sounds like your lanyard switch has been activated.
I did that last year by accident and got my motor doing that while the key was held on with the starter turning the motor and the throttle open. Smoke, backfire and hell!
As soon as I remembered the switch it fired right up!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Kill lanyard/switch? HiLiner Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 August 23rd, 2007 01:37 PM
Lanyard kill switch? cobra 3.0 Boat Topics and Questions (not engine topics) 8 August 8th, 2004 05:07 PM
Lanyard Kill Switch jfholijr Mercury & Mariner Outboards 8 May 25th, 2004 08:26 AM
Lanyard kill switch EvinFla Johnson & Evinrude Outboards 3 May 19th, 2003 04:59 AM
What is a lanyard kill switch? Neikensnest Non-Repair Outboard Discussions 2 September 2nd, 2002 05:36 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
