QC
- Mar 22, 2005
- 22,783
I am installing a rudder soon on a project boat. 20 footer, I/B 260 bhp. I have the rudder, stuffing box and associated hardware. I also have an old car manual steering box like used in early Chris Crafts which I might use. I measured 8 inches of travel to turn the rudder a full 90 degree swing with the "tiller arm" that I have now. It is five inches from the center of the rudder shaft to the center of the end of this arm. I am guessing that 45 degrees from dead ahead either way would be a reasonable starting point, thus the 90 degrees.
With that info as background. Are there any standard rules of thumb for rudder installations? Range limits? Force requirements for steering controls/cables? I can't imagine a typical rudder for this size boat would require anything close to OB and I/O requirements. I may use some simple cables and pulleys that I could fashion myself. I literally don't need anything else if I use the steering box I have. It is heavy, but has been rebuilt and operates smoothly etc. Thoughts?
