Tscott8201
- Dec 13, 2007
- 18
Hi,
I have a 22.5" aqua sports and surprise surprise the deck has several very large soft spots, and the T tops moves around quite a bit due to the movement of the deck. I cut an access hole in the deck and have confirmed that the core material (Balsa I think) is wet and basically useless. The rot seems to have started around the T tops. I think the reason is that the spots where the legs are mounted to the deck are not reinforced in any way.
So my plan at this time is to remove everything from the deck and then carefully remove the top layer of glass. Then i will have to devise a way to laminate mounting blocks to the stringers (from what I can tell they may be in the right place to do this) to strengthen the areas where the T top mounts. Then I will replace the core material and attempt to re laminate the top layer of glass back onto the deck.
I have a few questions.
First of all, I have never done this. I have seen it done and consider myself pretty competent with these types of procedures. Honestly though how much of a PIA is this going to be?
Should I use a balsa core material or replace as much wood as i can with a foam?
If I cut holes into the bottom layer of glass, how do i fill in this holes (I don't think I will have very good access to the underside of the deck)?
Has anyone here documented a similar project on a boat? Pictures would be great but anything is better than nothing. I have found a PDF of a small scale version of this repair on the deck of a small sailboat.
And finally, this is everyones last chance to tell me to give up and buy a new boat. LOL But seriously that is not an option, so I have got to fix it or pay to have it fixed and I am pretty sure the latter is going to cost me a ton of cash. Also, i have a great indoor space to do this where the boat can sit for months at a time if need be.
Sorry for the long first post but I have got to get this done right.
Tom
Tom
