Quote:
Originally Posted by daveswaves
Heres a trick I use on my 75 1150. Pump the bulb up hard, tilt the engine up all the way and then back down again, yup the fuel spills over when you tilt it up and then runs into the crankcase when you put it down. I added power tilt on mine so up/down and away we go.
Yep, YA GOTTA flood it! That will work fine.
Do it with the (for a check) cover off, motor tilted, and pump the bulb. When gas flows out the carbs, lay her down and go for an instant ride.
Just put together a crank up 135 72 rebuild for my 15 Flatbottom. A BEAR to start, but SHE LIKES GAS!
Rebuilding the carb float/neddles probably the worst thing ya can do...hard to over power them with the bulb.
There is an electric pump "Primer" off an Evinrude that can also be hooked up, but, thats something my Merc Guru knows about.
Do the tilt and pump...then try it..(and keep timing at 21 degrees, and run MidGrade gas.. )
Hope this helps..
