Re: portable gas tanks on crestliner 1600 fish hawk.
At 17.5 feet, its hard to keep everything separate in my boat. What I have done, however, to keep electrical sources away from fuel as much as possible.
I have side mounted, aluminum saddle tanks for fuel, with external fillers and vents. With the exception of the engine controls, all of the wiring runs underneath the port rail. My battery switch is on the port side, as is the distribution block. Both batteries are mounted in boxes and are secured under the splash well. The boat had a hinge mounted door enlcosing the battery area when I bought it and I immediately took that off.
With the exception of the fuel feed line from the port side tank, All fuel lines are run on the starboard side. Where I had to run wires near the port tank lines, I enclosed them in flexible plastic conduit. The fuel/water separator for the fuel system is mounted opposite the battery switch, on the starboard side, and the tank selector valve is on the starboard side, right next to the helm position.
