Frank, if your still out there, I got my powerhead and all looks good. It has everything on it including the exhaust tube. I got a CD off eBay but can't fallow it well so I ordered a Clymer off eBay and will wait for it to get here, I'm just trying to get up the guts to tackle this job. Also, I went to drain the lower unit and (yup), I pulled the shift pin instead. I move nothing and put it back in and then learned on my CD that if this pin is removed you have to tear off the lower gear housing and put it back in. I have read some posts on this tonight and then went out and put it into gear and the prop did not move, I took it out of gear and the prop spun freely, I put it in reverse the prop held. Do you think I'm OK there, also how much play should there be in the prop when in gear. Thanks Frank and all the others on this wonderful site. I can only hope I can become as informed as you all to help someone down the road. Chris
