  #1
Old February 21st, 2008, 10:52 AM
Rifflerunner17 Rifflerunner17 is offline
Default Evinrude powerhead bolt torque specs ?????
Anyone know the proper rowerhead bolt torque specs for a 91 15 hp Evinrude? Is it 15-17 lbs???
  #2
Old February 21st, 2008, 11:04 AM
HighTrim's Avatar
HighTrim HighTrim is offline
Default Re: Evinrude powerhead bolt torque specs ?????
That sounds right. Be sure to follow the correct sequence as well when torquing.I am unsure of the exact amount of bolts on that cylinder head, but the same idea applies, where a number represents a bolt. You start in the center and work out is a circular fashion.
9..................10
5...................6
1...................2
4...................3
8...................7
__________________
Chris
  #3
Old February 21st, 2008, 12:05 PM
Thanks much! I forgot to mention that I am looking for the torque for the bolt that attach the powerhead to the exaust housing. Would that still be 15-17 lbs torque? It is a 6 bolt setup.
Rifflerunner
  #4
Old February 21st, 2008, 12:20 PM
HighTrim's Avatar
I am not certain, but on my larger hp motors, it is 14 to 16 ft/lbs, then re torqued to 18 to 20 ft/lbs after motor test.
Hopefully someone will be able to verify these numbers for your outboard.
__________________
Chris
  #5
Old February 21st, 2008, 10:04 PM
Lakester's Avatar
Lakester Lakester is offline
Quote:
Rifflerunner
hello,
generally, 15-17 ft-lbs is in the range of a 3/8ths bolt. so be sure of ur bolt size, unless u source specs per the oem service manual.
regards,
lakester
__________________
Lakester Special
'71 85HP Evinrude
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
65 evinrude 9.5hp head bolt torque specs yostep Johnson & Evinrude Outboards 1 June 20th, 2007 10:42 PM
25 hp head bolt torque specs? CatfishClipper Non-Repair Outboard Discussions 1 April 25th, 2005 03:10 AM
25 hp head bolt torque specs CatfishClipper Johnson & Evinrude Outboards 0 April 21st, 2005 02:29 PM
head bolt torque specs 83 johnson 75 3cyl rforbes1646 Johnson & Evinrude Outboards 1 November 19th, 2004 11:13 AM
head bolt torque specs 9.9 gamefisher96 model ? cpwebster Non-Repair Outboard Discussions 0 May 10th, 2002 09:32 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
