Just bought a used 2004 Johnson 40HP outboard from the previous owner who wanted a larger motor. Owner said that after I get everything hooked up that I should run 50:1 premix through it until I'm sure the oil injection is working properly.
Makes me nervous. Considering just running premix and not worrying about hooking up the oil injection. From reading other posts it sounds like that can sometimes be a problem if the motor uses the injection oil for other lubrication purposes. Is that correct.
