Fuel Leak Fuel Pump x2 2000 Yamaha f100tlrz
I'm having problems with the engine at wot it will haul at 6k rpm for couple minutes then surging to between 5k and 5.5k rpm sometimes lower. pumping the primer bulb helps but is not consistent with getting the rpms back up. with the engine off and top cowl off i pump the primer bulb and there is gas seeping out of the gaskets of the top cover of both fuel pumps, to the point of dripping, i tightened the screws and still same thing. Is this normal? or do i need to replace the diaphragm and gasket or both fuel pumps. Thanks for your help
