Re: 2000 Mercury 175 efi starting problem
could be plugged injector filters or a fuel rail pressure proble. what is rail pressure? you can also try to squirt a bit of premixed fuel into the intake, if it runs briefly you will know its fuel
the EFI tester from mercury can test the injector firing as well as the injector commands from the ECU.
