Took the boat out fishing todayy and it ran great all day. Got back to the marina and while loading the boat back on the trailer the engine stuttered and died at idle. Tried to restart . It to longer than ususal to restart and had to use warm up lever to rev up then went to put in gear at idle then stubled at died again. Used the trolling motor to get it to the trailer then wenched up as others were wanting to use the ramp so I didn't have time to fiddle with it. Got it back to the house and put it on the muffs and cranked up stuttered a few time at idle then seemed to line out. Upon pulling the cowling for inspection I found the little hose that goes from the bottom of the breather box to the intake had come loose. Could this hose have caused my symptom or is that simply to lead fuel dumped from extreme tilting back to the intake. I know on my truck I've had a vacuum line come loose and cause idle issues. Could this be a similar situation?
Thanks John D.
Thanks John D.
