  #1
Old February 18th, 2008, 02:22 AM
gotboostedvr6 gotboostedvr6 is offline
Default 1765 or 1780
Now, a day before i was going to leave a deposit on my 1765 I'm having second thoughts on if I should just buy the 1780.
Let me get you up to speed
Just before i sold my 16 foot Glasstron-Carlson CV-16 I mounted a 04 Yamaha 25 hp 20" 4 stroke tiller on it and went for a test ride. If memory serves it pushed around 25-26 mph on my GPS and didnt take too much to get on plane, about 14 mph. That hull was around 900lbs and had a really deep v and was very bow light.
That taken into consideration, the 1765 and the 1780 both are lighter and are both Flat bottom. One is 65" at the beam marked from the chines the other is 80". They weigh 750 and 800lbs respectably. being that they are flat bottom they should get on plane at a very low speed. I'm wondering if anyone thinks there would be an issue with pushing 3 people at 600 lbs total with the 1765 or 1780 hull and motor with only a bench in the boat, no console or front deck so they might even be lighter then 750-800 lbs.
Fuel economy and light weight are king as i will be using this boat in the Delaware chasing stripers in 1-3 foot of water over rocks.
It will also serve as my bay and inlet boat, with the occasional trip outside
gunnel height is around 32" for the 1765 and 35" for the 1780
DLX 1765
Print this page
LOAwhat is this? .............16' 11"
DRAFTwhat is this? .............3" to 6"
BEAMwhat is this? .............77.25"
GUNNEL HEIGHTwhat is this? .............
TRANSOM HEIGHTwhat is this? .............15"20"/25"
DEADRISEwhat is this? .............0
BOAT WEIGHT .............800 lb.
WEIGHT CAPACITY .............1515 lb.
MAX PEOPLE .............8
MAX HORSEPOWER .............75 HP
DLX 1780
Print this page
LOAwhat is this? .............17' 2"
BEAMwhat is this? .............93"
TRANSOM HEIGHTwhat is this? .............15"/20"/25"
BOAT WEIGHT .............850 lb.
WEIGHT CAPACITY .............1800 lb.
MAX HORSEPOWER .............90
  #2
Old March 18th, 2008, 12:20 PM
Boat Drinks's Avatar
Boat Drinks Boat Drinks is offline
Default Re: 1765 or 1780
I personally don't like the 1780 but have owned the 1765 in the past before they went DLX. I am considering buying either the 1655 or 1765 and putting a four stroke 25 Honda on it. I had a 40 2 stroke on the 1765 I had and it would fly. On the 1655 I had a 25 merc and it did quite well too. One day I had 1200 pounds of bait and myself and it would still plane in shallow water. I've had friends that had the 1765 with 25 2 strokes and made out ok with the power and they probably carried more weigh than you're looking at. The extra width on the 1780 would make the boat carry more weight but I think you would be sacrficing turning personally. Good luck and keep in mind those boats will slide in a heartbeat. They don't have the reverse chine like the Southern Skimmer has so watch those high speed turns.
  #3
Old March 26th, 2008, 07:38 PM
thanks for the info
  #4
Old July 7th, 2008, 01:27 PM
VTSasquatch VTSasquatch is offline
I may be too late but I just joined the site. I have a 1965 with a 50 hp and I feel that it is a bit underpowered. It goes about 22 mph at 5000 rpms. I used to have a 75 hp and that moved the boat much better. I think a 25 hp in either of those hulls is pretty small. You may want to consider selling that engine and getting at least a 50 hp.
As far as taking the boat ito the ocean, the 1780 will be much harder to capsize, although neither are really ocean boats. I have had mine about 5 miles out but every swell makes me nervous. I think the extra width of a 1780 would make it feel much more stable in the swells. Let us know what you decide.
  #5
Old July 7th, 2008, 02:34 PM
I just bought a 2000 F50 yamaha and will be looking to get into the 1780...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Need Manual on Renken 1780 Seamaster!! Rose Fogarty Renken Boats 3 May 21st, 2007 05:29 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
