1995 2150 Striper, 5.0 VP SX Cobra
I have ordered and am waiting for the shop manuals...but following is my understanding of "routine" maintenance for this sterndrive.
-drain gear lube
-remove outdrive
-check all bellows (? what do I look for...or just replace?)
-check engine alignment (need tool)
-check the gimbal bearing (? what do I look for)
-check the u-joints (? what do I look for)
-grease everything
-install drive with new gaskets/seals (kit #?)
-fill gear lube
-grease prop shaft
Does this sound correct? Anything else I should check or do?
Thanks for any help
-drain gear lube
-remove outdrive
-grease everything
-fill gear lube
-grease prop shaft
Thanks for any help
