Leak test explanation please!
Nandy
I am familiar with the presure test on each individual cylinder but have read a few members here advising this test. Can anyone that is familiar with the test elaborate on it? How it is done, how to interpret the restults and what are the typical results (if there is a typical result). I would like to hear from someone that does the test rather than someone guessing what it is.
THANKS!!!
flabum
Re: Leak test explanation please!
Cylinder leak-down test: A cylinder leakdown test uses compressed air to pressure up the combustion chamber with the piston locked in the TDC position or in any postion before port opening. The idea is to see how well the cylinder holds pressure by measuring how much loss there is. Typically 10% - 15% loss is acceptable, most of us shoot for the 90%+ range. If there is excessive leakage, using this method you can quickly diagnose the problem by listening to where the air is escaping: If you hear it comming out the exhaust that would indicate bad rings. If you hear it comming out of an adjacent spark plug hole, this would indicate a blown head gasket or warped head.
Some will argue that a leak-down test is more accurate than a compression test but that is not necessarily true. It does, however, allow you to pinpoint the problem if one exists. I will do a compression test first then break out the time-consuming leak-down tester if it fails the compression test.
Nandy
Thanks! is the testing gauge/cylinder combo expensive? I might consider investing on one.
Nandy
I dont have a shop so I think the $125 will be adecuate. It is mostly for my personal use. Maybe help a friend or two. Thanks for all the information!
