Howdy, bc98usa.
Welcome to iboats.
Compression
ratio is pretty irrelevant in 2 strokes. What you are interested in is compression pressure, in pounds per square inch (psi), matching in the cylinders.
Because of differences in guages and technique the actual numbers don't matter much as long as they are in the vicinity of 100psi or above. What matters most is how closely the cylinders match each other. 15% is about the maximum allowable difference, and under 10% is considered good.
