jeff_smith_0423
- Dec 5, 2007
- 492
Evening all. New to this forum but I've been browsing for a while. Seems like an extremely knowledgeable group.
I recently bought my first boat. A 1971 Caravelle 15' Tri-hull, with a 1977 (i think - haven't verified serial#) Mercury 850. I bought the boat in non-running condition. The previous owner stated he started the motor once or twice a year up until this spring. He's never had the boat in the water. When he went to test start it this spring, it would not fire. It will run for a few seconds on starting fluid.
Obviously the gas has turned. The boat has a permanently installed fuel tank, which i've disconnected. I rigged up a generic wal-mart fuel line and portable gas tank and attempted to start. I had the same experience. It'll run on ether for a second or two, but nothing after that.
The fuel in the old lines stunk like hell, and was black/brown with varnish.
Suggestions where to start? I'm new to outboards and i havne't been on a boat since I was a teenager. I would suspect i need to clean the carbs. I've ordered a service manual but who knows when that'll get here. Any quick-fix things i should check?
Thanks!
Thanks!
