Reinstalling lower unit on mercruiser
Jami Laster
I am changing the impeller in the water pump as preventative maintenance on my 1999 Caravelle with a 3.0 L Mercruiser Alpha I Generation II. When I seperated the lower unit a piece fell out. It looks like a semi-circle metal piece with some silicone or rubber type substance covering most of it. It looks like it might fit around that 90 degree shift lever? Anyone know what this is and how it goes back?
tommays
Re: Reinstalling lower unit on mercruiser
http://www.boatfix.com/merc/Servmanl/14/14notice.pdf
the full manual you click on the ABC letters on page 4 to open each section
http://www.boatfix.com/merc/Servmanl/14/14b3.pdf
the water pump is down on page 75
Did you remove the drive OR drop the lower unit :confused:
it is a bit hard to do without pulling the compleat drive as small parts like the black quad ring are all that is keeping in the oil when you put it back toghter
47b7d700b3127ccebc78174ed8e100000036100AaOWLZq3ct2IA
Tommays
Ayuh,.......
While I've never seen 1 get That far down the exhaust path,.......
It Sounds like a half a Exhaust Flapper.........
They usually get hung up like this 1 on the shift shaft............
Oh,+ by the way,..........
Welcome Aboard to the forums here at iboats.com....................................... :)
Jami Laster
It seems to be that is what it is, half of a water flapper or water shutter. I talked to a parts salesman and he said that volvo took theirs out because it could do more harm when it fails and he said there is no telling how long it has been bad and he wouldn't replace it. Any thoughts
Haut Medoc
It is a cheap & easy fix on a Mercruiser & can potentially save you from water intrusion..... ;)
Ayuh,..........
Personally,......... I wouldn't run without them,...............
Besides,........
You've got to pull the Exhaust System apart to see whatelse is Burnt Up.........
Your motor was Obviously run with No Water at some point................
