Bill kubiak
- Jan 31, 2004
- 629
ref my earlier post about changing water pump impellor and disconnecting the shift rod.
I have the motor back together, started it up and water trickles out of pee hole but is gushing out of the leg anywhere it can. The question is about that housing on the water tube itself. can it slide up and down the tube and is there a proceedure to install it properly on the top of the pump before re-installing the LU. The housing is far enough up in the the leg to be difficult to tell if everything is lined up before tighening up the bolts.
