  #1
Old February 14th, 2008, 12:48 AM
cpr1717 cpr1717 is offline
Default painting aluminum boat?
hi i was gonna paint my 16 ft deep v aluminum boat. and im not shure where to start, the paint on there is in pretty good shape so could i just paint over it. and if so do i need to prime it and sand???
thanks
  #2
Old February 14th, 2008, 01:20 AM
JimMachinery JimMachinery is offline
Default Re: painting aluminum boat?
If the paint is holding well, you should be O.K. just spot-priming any bare metal with zinc oxide self etching primer and scuff sanding the existing paint for adhesion. I read a lot of posts and it seems to me most people like one component paints like Petit Easypoxy for aluminum boats. I used it on the bottom of my hull and was very happy with the result. Are you planning on spraying or using the roll-n-tip method?
Good luck,
Jim
  #3
Old February 14th, 2008, 01:25 AM
drewpster's Avatar
drewpster drewpster is offline
It depends on the paint you are going to use. Generally it is best to do a good cleaning (denatured alcohol or lacquer thinner works well), then sand the surface lightly with a fine grit to a haze. Then clean it again to remove sanding residue. This will provide a good bond for the new paint.
Every paint has its own procedure so be sure to follow instructions.
__________________
Every Hunter that takes the best Deer and every fisherman that takes the best fish at the moment of that happening looks to heaven to thank the one that provided it for thanks is the first thought that comes to mind.
Link to 'Nostalgic's Resto
http://s136.photobucket.com/albums/q...ter/Nostalgic/ (scroll down)
Link to the tri-hull transom job.
http://s136.photobucket.com/albums/q.../thundercraft/
  #4
Old February 27th, 2008, 10:17 PM
Kyshorthair Kyshorthair is offline
On my 91 Alumacraft mod v I did a light sanding on the original paint and used Parkers Duck boat paint and it has held up really nice. I brushed and rolled it on. Looks pretty good to me. Its an oil base paint that is designed for boats. I thought it went on really smooth. It only took less than a half gallon for my 15 foot boat, inside and out. I've got plenty left for touching up the nicks and such that happen with river fishing. I'd wait until you have some good warm and dry conditions to paint in. Good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
painting an aluminum jon boat. mschex05 Boat Restoration and Building 2 June 9th, 2007 09:44 PM
Painting Aluminum boat mattconlon Boat Topics and Questions (not engine topics) 7 June 22nd, 2004 01:10 PM
Painting Aluminum Boat Rick K Boat Topics and Questions (not engine topics) 6 October 13th, 2003 09:38 AM
Painting aluminum boat Tackle Box Boat Topics and Questions (not engine topics) 5 August 13th, 2003 07:55 AM
Painting an Aluminum Boat springbok Boat Restoration and Building 2 August 12th, 2003 08:26 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
