Bill kubiak
- Jan 31, 2004
- 629
In a previous post It was suggested I get an impact driver to get the drain plug out? I'm getting that today when Harbor Frieght opens.
I noticed it has a hollow swivel tube for tilting the motor, There is a big nut on the right side of that tube, I am guessing I remove that nut, slide the teleflex cable thru the tube and then screw down the nut on the teleflex steering cable. There must be a special part to connect the end of the teleflex cable and then to the motor to make it turn.
What does that part look like? any pictures out there? Can I fabricate something so I can steer it with a wheel?
I also noticed a small plate on the right side of the motor that is removable and I am guessing that is where the remote shift/throttle cables go into the motor. This motor has the shift in the twist grip, can it also use remote controls?
I know this is a lot to ask and I hope that you can help me out.
