  #1
Old February 13th, 2008, 11:24 AM
natecollins1 natecollins1 is offline
Default 1979 Mercury 80 hp starting problem
Hi,
I am working on a 1979 Mercury 80 hp outboard. I am only able to get it started if I fully advance the timing arm on the motor or using the warm up lever (which does the same thing on this motor). At first I thought the problem might be that it did not have the proper fuel mixture when starting. I tried to start it using the choke with no success. Next, I tried to spray some starter fluid w/ lube at start up, again with no success. Last, I tried to start with the carb butterfly valves wide open - again w/ no success. It only starts if I fully advance the timing arm. Once I get the motor started it idles a little fast (probably 1000-1200 rpm). Also, the lowest I can get the idle timing down to without cutting out is about 6 btdc. The spec calls for between 2 btdc and 2 atdc. I have adjusted the idle mixtures screws to what I believe is the sweet spot. I am about a 1/4 turn richer than the spot where I notice a change in rpm. I did a spark test with a spark tester and all cylinders are getting a good spark when cranking.
Please help. Thanks.
Nate
  #2
Old February 13th, 2008, 01:27 PM
hkeiner's Avatar
hkeiner hkeiner is offline
Ensign
Default Re: 1979 Mercury 80 hp starting problem
Have you done a FULL link and sync, from beginning to end? Each link and sync step/setting is dependent on all previous steps/settings being correctly done. If one step/adjustment is incorrect, it negatively affects any subseqent steps/settings you try to do/adjust.
__________________
1996 Mercury 150HP V6 carbed outboard motor and Maxum 1900XR bowrider boat
  #3
Old February 13th, 2008, 02:08 PM
Hi,
I have done a complete sync-and-link. The best I could get was about 6 dbtc when adjusting the timing without having the engine cut out. I performed everything just as the mercury service manual specified.
Thanks,
Nate
  #4
Old February 13th, 2008, 02:12 PM
j_martin j_martin is offline
If you skipped the test where you measure the piston dept before TDC and compare it to a flywheel mark, that is where your problem is.
Assuming you have good compression, sounds like yer timing mark is off.
hope it helps
John
  #5
Old February 13th, 2008, 06:06 PM
Hi,
I checked the timing mark using a dial indicator as the service manual states. It is dead on.
I took the boat for a ride today on the water. It was having a little bit of trouble cutting out when I shifted it into gear. It was also appeared to be starving for fuel when I accelerated. I was able to push the choke when accelerating and it gave it a little more power. I will clean the carbs to resolve this issue. I probably have some trash in the high speed jet.
I am still stumped about the fact that I have to advance the timing all of the way to get it started.
Any help is appreciated.
Thanks,
Nate
  #6
Old February 13th, 2008, 06:22 PM
Chris1956 Chris1956 is offline
Wink Re: 1979 Mercury 80 hp starting problem
Nate, Before you clean the carbs, richen the idle mixture 1/8 turn, top carb first. Then try to accelerate. If you need to richen the bottom carb, do that next. You should get a lousy idle but good acceleration, that is normal.
As for your timing issue, on my '77 distributor Merc 1500, the idle timing was 4-6 BTDC. So, you may be Ok on that one. Make sure you do not adjust the primary pickup, once you have set it to 4-6 BTDC. Just back down the idle stop and cable barrel to slow the idle RPM.
  #7
Old February 13th, 2008, 06:44 PM
Hi,
Thanks for the info. While I was out on the lake today I did try opening up the idle mixture screws about a 1/4 turn. This did help some, but I could still feel some trouble accelerating.
I also did as you said about the sync-and-link. Where I have everything set now, if I adjust anything to slow the motor down it will die out.
I will probably try cleaning out the carbs next and that way I will have one less thing to worry about while making my adjustments.
Thanks,
Nate
  #8
Old February 13th, 2008, 06:49 PM
hkeiner's Avatar
Ensign
Fuel starvation can be a serious situation. If you run the motor too lean at high speed, you can burn up the pistons and such. To relieve any concern over possible fuel starvation caused by a weak fuel pump or the fuel system upstream of the fuel pump, there are tests you can do with a vaccuum gauge and some clear hose. Mercury issued a Service Advisory that describes how to do this.
If it is "starving" only during accelleration, then the excellent advice you already received, regarding adjustment of the carb jets, should do the trick.
http://www.marinepartsman.com/Mercur...2001/EN_17.PDF
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1979 140 hp mercury choke problem starcraft18 Mercury & Mariner Outboards 7 June 29th, 2007 08:58 AM
1979 140HP Starting problem lp142 Johnson & Evinrude Outboards 1 April 4th, 2007 11:47 AM
1979 115 hp Mercury outboard switch box problem bustten Mercury & Mariner Outboards 2 September 19th, 2004 07:05 PM
1979 115 hp Mercury outboard switch box problem bustten Non-Repair Outboard Discussions 1 September 19th, 2004 05:13 PM
1979 Mercury 85HP tilt/trim problem jdheaden150 Mercury & Mariner Outboards 3 March 9th, 2002 06:21 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
