  #1
Old February 12th, 2008, 10:45 PM
pete32 pete32 is offline
Default 1986 mercury fuel/oil ratio
I just bought a 1986 mercury motor. The owner said that it was a 20hp and he had changed the carb. to a 25hp. I asked him what he used as the mixture ratio he said 36 to 1. When looking thru this site it seems that eneryone is saying 50 to 1. What is the correct ratio and octain to use when using this motor. Also this motor gets used at altitudes from sea level to 7000 ft.
Thanks for the info.
  #2
Old February 12th, 2008, 11:19 PM
j_martin j_martin is offline
Default Re: 1986 mercury fuel/oil ratio
50:1 is the correct ratio. Use good oil. I doubt the carb story also.
I'd read the plugs after a hard run at sea level to be sure you're not too lean, otherwise shouldn't be a problem.
hope it helps
John
  #3
Old February 12th, 2008, 11:22 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
The correct mixture is indeed 50:1 no matter the altitude. In fact, a richer oil mixture will somewhat reduce the fuel combustibility, not to mention foul the spark plugs more often..
__________________
Rick
"Boating is Life...All the rest is just Details"
  #4
Old February 12th, 2008, 11:23 PM
Ranger_man Ranger_man is offline
50:1 regular, but I heavily suggest 100:1 AMS oil.
  #5
Old February 12th, 2008, 11:59 PM
Quote:
If you want to wreck yer motor. If an engine (like the 1930's stuff) needs 16:1, and you use a TCW3 oil capable of ;100:1, you mix it at 16:1 for that engine.
Manufacturer spec for your engine is 50:1. No matter what oil you use (provided it meets minimum spec, which is TCW2, I think) you mix it at 50:1
Sorry Ranger, I've seen too many wrecks by AmZoil.
John
  #6
Old February 13th, 2008, 12:28 AM
Could he have damaged the motor if he ran it at 36:1? Also he showed me the carb that he replaced it had a much smaller opening than the one that was on the motor. The guy I bought it from was a mechanic and had the motor for a number of years. Just seemed like if he was running it at 36:1 he would have had issuses with the motor.
Just want to make sure I'm doing the right thing.
Thanks for your info.
  #7
Old February 13th, 2008, 01:20 AM
Naw, that ignition will burn 25:1 with little trouble. In fact, that's how you're supposed to break it in. It's just a waste of expensive oil on a smooth free engine.
Just slapping on another different carburetor without carefully dialing it in at all speeds can cause trouble. If it's too lean at any speed, it could actually burn down the motor. I don't know about that particular swap, but someone here does and could make a recommendation for jetting or adjustment.
If it seems to run good, I wouldn't worry too much. If you've a mind to, you could idle for awhile, then check your plugs. Put in new ones, run wide open for awhile, then check the plugs. Then again at mid range, just to be sure the carburetion is dialed in.
I'd recommend getting the oem maintenance manual, and do the "link n sync" procecure in the manual. It'll give you a good feel for how the motor is supposed to behave, and also assurance that it's set up right. You should really do this before you dial in the carb.
hope it helps
John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Oil to Fuel ratio for 1971 Mercury 9.8 hp muniacmaniac Mercury & Mariner Outboards 2 August 15th, 2007 07:46 PM
Old mercury 7.5 fuel/oil ratio question... toxx Mercury & Mariner Outboards 2 June 10th, 2006 07:28 AM
Mercury 25 fuel oil ratio & rpm scso377@snowcrest.net Mercury & Mariner Outboards 1 July 27th, 2004 08:45 AM
fuel/oil ratio mercury 85 grailton Mercury & Mariner Outboards 2 July 12th, 2003 12:26 PM
fuel/oil ratio '85 mercury rustybol Mercury & Mariner Outboards 1 May 31st, 2001 04:15 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
