mercury 150 jets
jims3000
does anyone know where to get a inline 150hp carburetor main jets from.rebuild kits dont come with them?
achris
More fish than mountain goat
Re: mercury 150 jets
They are still available form Mercury. If you post your engine serial number I can give you the part number for them. They are about $4 each.
Chris..........
jims3000
4868995 and do they have a web site you can order them from,thanks
achris
Your engine is a 1500XS and the main jet is 0.082", part number 1399-3518. If you want to get them on-line try mercruiserparts.com or Mercury Marine direct (mercurymarine.com) and go to the 'shop'.
Chris.........
AMD Rules
Hey Chris,
How did you determine that motor was an 'XS'? Do you have access to a Merc database?
For example, the chart I have would suggest it could have been a 1977 E, EL, ELPT or a 1978 XS but I cannot distinguish which without knowing more details about the motor.
Just curious.
achris
Hey AMDrules,
I used the parts catalog look-up, not the starting serial numbers. The non-XSs finish at 4868647, according to the parts catalog.
Chris...........
jims3000,
What size are the jets you removed?
Cheers..........
achris
Jim,
Why do you think they need replacing?
Chris...........
jims3000
after nearly 20 years of running fuel through them they probably need changed not saying their is something wrong with them just doing a carb rebuild and would like to replace everything.on another note i have done plumming work for several years and water running through copper pipes eat away at the inside of the pipe same may go for jets gas going through the hole may make the hole bogger after awhile.my theory anyways.
