  #1
Old February 11th, 2008, 07:55 PM
jakestevens jakestevens is offline
Default 1964 Evinrude 40 hp Lark 6 lower unit
Hey everyone! I just joined the forum, and I'm gathering much info so far, thanks.
I just bought an old fishing boat with a 1964 Evinrude 40 hp Lark 6. I put the boat in the water and ran it for about 5 min. I let the boat sit overnight with the motor down. When I arrived home today, I noticed milky fluid leaking from behind the prop. I removed the prop and the 4 screws at the back of the torpedo housing. I removed the piece which the 4 screws was holding and of course everything is milky white. This is obviously water entering the lower unit.
What seals would be the culprit for this problem? What is my next step in this process?
I have some experience with Mercruiser lower units, but never had my hands on anything like this. I wanted to get some input from some of you guys on this.
Thanks a lot.
  #2
Old February 11th, 2008, 08:07 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1964 Evinrude 40 hp Lark 6 lower unit
Welcome to iboats. sounds like you are in for a complete reseal, is the best way to go. looking at my manual you are going to need one. it shows it is an electric shift. manual "http://www.outboardbooks.com/index.cfm?fuseaction=models.main&year=1964&ID=5390 1"
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old February 11th, 2008, 08:44 PM
thanks for the info. Where on the engine would I find the model #? There were several listing on the website for 1964 40 hp envinrude outboards.
thanks again.
  #4
Old February 11th, 2008, 08:45 PM
F_R F_R is offline
Most people tear the wires off the shift coils the first time they take one of those things apart. A very expensive mistake. Get a manual and DON'T let the torpedo section drop down when you unbolt it.
  #5
Old February 11th, 2008, 08:47 PM
F_R F_R is offline
Model number
  #6
Old February 16th, 2008, 06:35 PM
I have the manual and it is very informative and will be a great tool during the tear down. Is there a part # for a complete seal kit for this outboard?
The manual shows that I will have to completely tear down the outboard to replace the seals. Is this the case? If so, I feel confident about it, just don't want to do more than I have to.
Thanks everyone..
  #7
Old February 16th, 2008, 07:50 PM
F_R F_R is offline
You do not have to completely tear it down unless it is leaking where the lower case joins the upper one...and they generally don't leak there unless one of the studs is broken. Drive shaft seal is under the water pump and accessable once the pump is off. You already see how to replace the prop shaft seal because you have the bearing head out. Don't forget the little o-rings on the 4 screws holding that part in.
  #8
Old February 17th, 2008, 02:27 AM
evinice66's Avatar
evinice66 evinice66 is offline
i dont really know anyhing compared to anyone on this site but if the fluid smells like gas it could be unburned gas and oil, in the faq section is where i read that.....
  #9
Old February 17th, 2008, 11:07 AM
Thanks for the info. Is there a part # for ordering the seals and orings for this outboard?
  #10
Old February 17th, 2008, 11:10 AM
HighTrim's Avatar
HighTrim HighTrim is offline
Here is one option. About $21.95 for the kit, halfway down the page.
"http://www.laingsoutboards.com/newpage4.htm"
__________________
Chris
  #11
Old February 17th, 2008, 11:37 AM
I have the electric shift model.
Would it make sense to replace the impeller, being that I'm right there anyway?
I did just purchase the boat and I'm unsure about the last time the impeller was replaced.
  #12
Old February 17th, 2008, 11:45 AM
steelespike steelespike is offline
Definately do the impeller.
  #13
Old February 21st, 2008, 11:47 PM
I removed the lower unit and I believe I found the cause of the water in the gear case. The seal on the impeller housing was broken and also the impeller housing is damaged. Looks like someone try to pry the seal out of the housing at one time and damaged it. Is the impeller housing something that is hard to find?
  #14
Old February 21st, 2008, 11:58 PM
HighTrim's Avatar
Laings carries the housing.
__________________
Chris
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1964 evinrude starlite 90 s lower unit frozen mikehooper420 Johnson & Evinrude Outboards 11 September 13th, 2007 12:37 PM
1964 evinrude starlite 90s lower unit diagrams mikehooper420 Johnson & Evinrude Outboards 4 September 3rd, 2007 01:45 AM
1964 Evinrude lower unit 665543 Johnson & Evinrude Outboards 19 February 8th, 2007 07:37 PM
1964 Evinrude Lark VI/40 Horse/Elect. Shift BassinVt Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 June 9th, 2003 06:08 AM
1964 28hp evinrude lower unit seals barely-a-wake Johnson & Evinrude Outboards 2 May 10th, 2003 04:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
