Re: duel yamaha multifunction guages problem
and your problem is ?
if wired correctly the fuel management,one tach and the speedometer will power up on the same keyswitch.
do you have the older style digital tachs or the command link?
if command link the meters are set up at the PDI, if somehow they get reset you will have to tell them which engine they are hooked to again.
