Any way to seal leaking rivots? Someone has tried to epoxie them from the outside and it cracks and gets rubed off the hull. Quite a few leaking. All under the decking.
The only sure way is to remove the rivets and install new ones with a sealing compound. Anything you try to smear over the rivets will crack and leak again. It's a case of doing it once and doing it right. Anything else is a temporary fix that will leak fairly quickly.
