71 Evinrude 25hp trouble starting
This motor was in storage for many years and it ran occasionally. After taking it out of storage, I took off and cleaned the carb , cleaned the points and was finally able to get it running however I don't know if I got the throttle linkage correct connecting the carb. I tried adjusting it some and now I cannot get it to start again. I think part of the problem is fuel mixture and part adjusting the linkage. I get plenty of fuel and spark in both cylinders but I just can't seem to get it running. Can someone suggest a good starting place to set the carb? Any advice is appreciated. Thanks
