  #1
Old February 9th, 2008, 12:32 PM
cvz19 cvz19 is offline
Default 1982 Evinrude Starting - starter disengages
I am having an issue with a 1982 Evinrude 175 HP not starting.
The engine fires a few times (less than a second) and the starter disengages right away and the engine fails to start. I thought this might be normal for the starter but not sure so I replaced the plugs and a plug wire I thought might be bad but still I cant get it stated.
So, should the starter continue until I release the switch or until the engine first fires?
I have new gas, am using the choke and idle lever and pumped the bulb.
I appreciate any answers or ideas.
  #2
Old February 9th, 2008, 04:57 PM
Benny1963's Avatar
Benny1963 Benny1963 is offline
Default Re: 1982 Evinrude Starting - starter disengages
hi i have a 150 that did the same thing had weak spring on bendix
also you need to check carbs / make sure your primer selinoid is is pumping
and search the topic on proper starting procedures and tuning
there is a ton of info on here
welcom bennyb
__________________
Benny B
  #3
Old February 9th, 2008, 05:04 PM
Silvertip Silvertip is offline
A battery that is not fully charged or has a weak cell will prevent the starter from spinning fast enough so the bendix drops out the instant the engine fires. Check battery cable connections (both ends) and make sure they are shiny clean and tight. If the starter worked ok before the rebuild, I doubt the bendix or spring went bad during that process. The starter is an "overrunning" design meaning when the engine is spinning faster than the bendix it literally throws the bendix away from the flywheel. If you count the teeth on the flywheel and divide that number by the number of teeth on the bendix you will see that the engine does not have to spin very fast to overrun the starter.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1982 Evinrude 115 HP starting problem blueblurr Johnson & Evinrude Outboards 7 February 8th, 2009 07:48 AM
loose starter 1982 Evinrude long shaft jrmcgee1972 Johnson & Evinrude Outboards 6 May 22nd, 2007 01:15 PM
V-6 150 starting issues... starter disengages too early Capt. Crunch Mercury & Mariner Outboards 11 November 9th, 2006 02:07 PM
Starter Pinion Disengages Prematurely bbonney@gci.net Johnson & Evinrude Outboards 10 April 12th, 2006 09:41 AM
Starter Motor Disengages too soon Grizznbow Johnson & Evinrude Outboards 9 November 17th, 2003 09:00 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
