Re: Changing powerheads
Chris: I don't remember your last post but I'm sure I replied to it.
Anyway, first thing you need to do is to remove your old powerhead. to do this, you must remove all wiring and carbs. Take off anything you can to make it lighter. Bare, it weighs around 100 pounds. So head and flywheel , stator and all electronics come off first. Then you must remove the lower pan. To do this, remove the six 7/16 head bolts holding it to the rear shroud, and I think there are six additional ones holding it to the front shroud. Lift it off. Remove the six bolts holding the rear shroud on then pry out the two pins at the bottom of it and remove it. Now the nuts holding the engine and match plate to the mid leg are visible. remove the six 9/26 nuts and six more in the front of the match plate. Disconnect the shift and then start to pry up the block and match plate.This is frequently difficult and time consuming. It would be best to have a little help at this point.
Once you get the block and match plate off the leg, you will see four more 9/16 nuts inside the match plate. remove them and using a rubber mallet, tap off the match plate and exhaust tube for use on the replacement engine. this gasket will tear and need to be replaced.
Once you get the match plate and exhaust tube on the replacement block, then you need to lift it onto the lec. You will need help here because you must tilt and turn it for the flange on the exhaust tube to clear the water tube mount inside the top of the leg. No gasket necessary between the match plate and mid leg. A little silicone RTV is all. Don't get too generous with it as it will squeeze out and partially clog some water passages in the match plate--you will see them.
If you have a manual, everything is pretty much straight-forward--except they don't tell you just how difficult it can be to pry up the old block off the leg.
Before you even attempe to mount the replacement, spin the flywheel which you will have temporarily put on for this step. Put your thumb over the spark plug holes and see if there is compression. This is just a rough go/no go test. If nothing here, then contact seller for a refund.
Once you mount the powerhead, assemble all subsystems and again first thing, check compression. Might not be a bad idea to remove the head when you firse get the block and eyeball the cylinders and pistons. If you do that, then you don't need to check compression with your finger.
After everything is assembled, --oops, gotta go. more tomorrow.
