  #1
Old February 7th, 2008, 08:25 PM
CatPontoon CatPontoon is offline
Default 89 Yamaha 4 stroke 9.9 HP Problem
I bought a pontoon last fall with a 1989 9.9 HP Yamaha 4 stroke. It starts easy, idles perfect and motors up right away. After a few minutes at any throttle setting above an idle there is a distinctive CLICK like a relay and it idles down. Never dies just idles down and stays that way for 30 seconds or maybe a minute then it clicks again and back to the correct throttle. I've worked on a lot of motorcycles but this thing has me stumped. Primarily because it's an intermittent problem. The only time I've had a similar problem it was low oil sensor on a 2-stroke on a big Yamaha. Any ideas? Any help is appreciated. Rick in INDY
  #2
Old February 7th, 2008, 09:42 PM
JB's Avatar
JB JB is online now
Default Re: 89 Yamaha 4 stroke 9.9 HP Problem
Howdy, CatPontoon.
Welcome to iboats.
You need to get the Manual and read up on that mad scientist's version of a non-electronic "computer" controlled carburetor.
I had one of those dudes for a while several years back. I don't have the manual anymore, but as I recall there are vacuum operated controls to adjust mixture and idle based on engine temp sensor and at least one more.
Sounds to me like one of those sensor/vacuum circuits is operating incorrectly part of the time.
__________________
RED SKY at night. . .
JB
  #3
Old February 7th, 2008, 10:41 PM
Yeah I've poured through the shop manual, trouble shooting section etc. None of the symptoms I have are in there. I'm hoping to not have to play the "replace each item until it runs right" game. Especially when it comes to non-returnable electrical parts. Sounds like sensor for sure. I'm thinking if it's a coil it would just die and not idle down. Thanks for the reply! Anyone else fought this fight?
Rick in INDY
  #4
Old February 11th, 2008, 09:12 PM
sdsaw sdsaw is offline
Hi CatPontoon,
These motors will retard the timing if they lose oil pressure or possibly overheat(not positive about this one). When I started having oil pressure issues due to a corroding oil, tank mine would not run above idle. You may want to check your oil filter to make sure it's not clogging up.
Hope this might help you.
__________________
"Somebody put salt in the ocean to punish us boaters"
1989 22' Bayrunner Cuddy (Aluminum)
2001 Merc. 115 Saltwater Series Fourstroke
1988 Yam. 9.9 High Thrust Fourstroke
1998 Dodge 2500/ 24V. Cummins diesel
  #5
Old February 13th, 2008, 12:49 AM
I'll check that out! Thanks for the reply!
  #6
Old February 19th, 2008, 10:40 PM
Just an FYI for anyone with a similar problem. After much digging it appears this model (as do many others) has a low oil pressure SWITCH not sending unit. If the oil pressure drops to about 8psi it tells the CDI to slow it down to about 1,000rpm. The switch should be open at pressure and close at low pressure which grounds the wire thus telling the CDI to back down but lets you get home. So I'm guessing a bad switch or at worst a bad oil pump. But being an intermittent problem I'm thinking the oil pump is OK. I'll be swapping as soon as I get a break in the weather and post the results. Thanks for the posts.
  #7
Old February 20th, 2008, 01:18 AM
rodbolt rodbolt is offline
why switch anything. simply put the ohm meter on it and watch the swith. its either open or closed.
memory is fuzzy but I believe some older models also had an oil level switch.
however I cant remember offhand.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 225 four stroke r/pm Problem trouble TS Yamaha & Suzuki Outboards 1 October 21st, 2005 06:21 PM
Yamaha 25 HP 4 stroke problem Clambone Yamaha & Suzuki Outboards 8 September 27th, 2004 06:20 PM
Yamaha 50 4 stroke problem DonHallman Yamaha & Suzuki Outboards 1 September 20th, 2004 09:12 PM
4 stroke Yamaha 50 WOT problem IanP Yamaha & Suzuki Outboards 14 July 27th, 2004 08:00 AM
Yamaha four stroke problem JohnNC Yamaha & Suzuki Outboards 0 July 28th, 2002 08:19 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
